Hey guys! Cool forum! I got a few questions that i would like answerin! 1. Is there any way i can add sounds to the start up and closin down wit my phone? 2. Does any1 know where to get good full screen gifs? If any1 can help then that would b great! Thanks!
Newbie! Few questions please!
well if you search the topics for attached .gif files you'll find loads! but you'll need sprofiles to get them moving when you set them as background.
and as for the sounds playing i really dont know my best bet is to use a file explorer and locate the startup .ini file and edit that! but im sure the phone resets that to default everytime it starts!
maybe j2k or someone can help you on this on buddy!
changing the .ini file only changes the start up picture and not the sound i think it is not possible to attach a sound on the start up
Why would you want to mess with .ini files and screw something up.
You can change the startup image in Tools-Setting-Phone-General-Welcome note or logo.
I can help here ... WOW ... For the first time ... 😃
There is a program called ActiveDesk, You can configure this to play a sound file during startup ... I think it's for the 7650, but I don't know if anyone has tried it on a 3650 so here's your chance ... 😉
Good Luck ...
BSK 😃
hello!
this is my 100th post!! :agrue:
@ sakaveli
Well done on your 100th post ...
Although you have a long way to go to catch up with GhostDog on his 3000+ postings
BSK 😃
sakavelin how did you get your avatar so big???:s
its linked to an off site picture! go to your profile and you can have one too! 😉
sakaveli,your avatar is too big,this has been discussed before.Remove it or resize it.
