Creating Midi Ringtones
12 replies · 2,841 views · Started 28 August 2003
Hi all 😃
Anyone have any idea how to create MIDI ringtones & if it's using something like cubase, how to get hold of the midi set for the 3650 ???
Cheers again ...
BSK 😃
***EDIT***
Plus I would like to say ... If anyone can help me out on this I would be more than willing to do some ringtones for them ... I used to create them on a 3210-3310 ... Plus I also use cubase ... So if i can get some help ... I should be able to create some kick a** ones (Perfect not some like organ sounding ones you get ...)
you have a 3650 right why don't you use wavs as your ringtone they sound great and are easyer to make
i had a app for my pc that allows you to make midi ringtones but could not remember the name, i'm going to search for it it is somewhere on this forum i will let you know
i have found it. it is calles anvil studio i don't know if you can create midi ringtones by yourself thats what you have to find out it have the program on my pc but it is to big to send it as a attachment
IMHO,in order to make/produce midi's you'll have to play then with a real synthisizer connected to your pc's or with a virtual synthisizer which usually comes with the sound card drivers.
@lars : I will have a look at that program ...
@GhostDog : I was just wondering if the MIDI set is the same though ???
BSK 😃
