Pic 1
some n gage pics for you
wow.. it's only a little bigger than Nokia 8310. I thought it would be as big as 9210
You can check www.siemenssx1.com for comparison between all Symbian devices.
On Friday 19th arrives de Nokia Tour to Madrid. I'll be there to do some hard testing on the N-gage. I'll tell you then what I think about it. I like the pics though It's just like I though it would be. Has anyone seen the 3300? Is just the same.
well, i think n-gage is a lot better than 3300, cause 3300 doesn't use Symbian OS, and it's just like other small phones from nokia
HI, I have N gage-commercial edition!
It is very intersting, but it is not very comfortable to use it. You have to talk on it very starnge-on the long side.
The Symbian is Ok, but is slower than my N7650. I will put some games and apps on it to see how it works. I will keep you updated
Hello Miro,its very unlikely that you have a commercial edition of the N-Gage.Maybe you should check what it says under the under the battery.
Unlikely, perhaps, but given that it is only a month to launch, still possible as Nokia would have to start manufacturing of the hardware weeks before October 7th in order to get it shipped to distributors/retailers in time for the launch.
