Hi,could anyone please help me-i am wanting to remove the pre loaded shortcuts from the favorites folder. When i click the 'c' button on them it says unable to remove. They are the ones linked to t-mobile but as i am now on another network i would like to remove them. I have Fexplorer on my phone but not been brave enough to just dive in there without some help (",) thanx. X
Removing favorites
[quote="Candi"]Hi,could anyone please help me-i am wanting to remove the pre loaded shortcuts from the favorites folder. When i click the 'c' button on them it says unable to remove. They are the ones linked to t-mobile but as i am now on another network i would like to remove them. I have Fexplorer on my phone but not been brave enough to just dive in there without some help (",) thanx. X[/quote]
Does this also happen when you press OPTIONS and select DELETE?
Hi,when i press options there is no delete option there.
Those shortcuts are on the Z: drive,so there is no way to remove them,unless you flash your phone with original Nokia firmware.
Correct me if i'm wrong.
Thanks Ghost Dog,if i get a software upgrade is that the same as flash?
No problem Candi.
Yes,software upgrade is the same as flash.
Note though, most NSCs will only flash your phone with the operator software, so the links will remain. I know this is true with Carphone Warehouse and Vodafone Live branded phones in the UK.
Have you also tried doing a manual reset?
My guess is that it won't work,becayse like i said,its a firmware package customized by T-Mobile,so the branding is on Z: drive and can't be removed.
Thanks j2k and mekeni,i think ghostdog is right though,i will need 2 get flash to remove them.
