DVD Ripper
7 replies · 2,587 views · Started 29 August 2003
Can anyone recommend a good DVD ripper?
Preferably one that isnt too expensive... :-?
Any help appreciated! :multi:
Try DVDx its a ripper and MPEG1 or 2 and AVI encoder all in one and its free. I use it all the time www.labdv.com
Stezos
[quote="Stezos"]Try DVDx its a ripper and MPEG1 or 2 and AVI encoder all in one and its free. I use it all the time www.labdv.com
Stezos[/quote]
DVDx is free, but to get to the download page you have to buy a 3 month VIP subscription to the site for $12. Still pretty cheap for some nice software...
Stezos, have you used DVDx to rip from a DVD and then converted the file for a P800? What conversion software did you use?
...ron
[quote="rclewen"]DVDx is free, but to get to the download page you have to buy a 3 month VIP subscription to the site for $12. Still pretty cheap for some nice software...
...ron[/quote]
I havent got the latest version I use 2.1 which i downloaded from another site ages ago so didnt have to buy a VIP subscription, if you search around on the net im sure you will find other places to get it from, but for me im happy using 2.1
Yes I have ripped using DVDx and created mp4 files to play on my P800. Using DVDx I create an mpg file (I personally find it better than AVI for converting to mp4) then once the mpg is created I use PVAuthor to create the mp4 file. Ive also tried Mpegable but find sometimes the lip sync can be terrible so prefare PVAuthor.
Stezos
[quote="BoBKiD"]...and what does this topic has to do with P800???[/quote]
What do you mean by that?
This topic is regarding getting a movie or tv programme off a DVD and onto the P800.... :turn-l:
Thanks for all the responses by the way guys! 😃
