A few days ago I sent a SMS to one of my friends, now the little sending message icon in the upper left corner (kinda looks like a horizontal [ with an arrow comming out of it) will NOT go away! I've tried everything I can think of, turning off the phone, re-booting with FExplorer, sending more SMS's, taking out the battery, but the icon WILL NOT go away! It's starting to drive me crazy... Anyone have any ideas?
Sending Message Icon Won't Go Away!
I have not heard of this before.. So this is just a suggestion.
What about backing your phone up. Doing a hard reset and afterwards restore your data.
Maybe that would do the trick.
Mmm try: Menu ---> Messaging ---> OutBox and check there isn't any sms failed to send... ( just delete it )
If any sms has failed the icon with the arrow will still appear 😉
Good Luck!
:roll:
it happened to me.. i did a hard reset and then it was gone..
My first thought was exactly what aeron said.. It might be that it wasn't sent..
have you looked in the outbox?
I can't believe I could be so STUPID :roll: ! I thought I had checked the outbox, but just in case I opened up the outbox and there it was. For some reason it said 'Deferred' under the message. I have no idea what that means... Either way, thanks a lot for the help, I never thought such a little icon could drive me so insane!!!
