films on 3650?
8 replies · 2,604 views · Started 29 August 2003
hi
i appreciate that the answers to the following questions are probably already on this forum, so my apologies if this is just treading water.
1. do any of the videocam apps allow you to make long recordings? 20-30mins?
2.is it possible to downsize movie files to play on the 3650? also is there a mediaplayer that gives you a fullscreen picture?
3.finally how do i transfer files/apps to and from my pc/3650 is there a data cable that comes with the phone?
thanks guys.
if you mean i should use the search option i already have for a good 20mins, and have failed to find anything related or in any way conclusive. i kno the answers are prob there, but as im a relatively new forum user i really am at a loss as to how to find the answers. some help would be really gratefully recieved.
thanks
for longer videos search for eti camcorder
for sending files to your phone use ir or bluetooth
and for full screen videos: don't know if it is possible yet
PVPlayer does do the trick ...
As far as I know though once you transfer a MPEG file to the phone, it converts it to it's native resolution which is not the same as the resolution of the whole screen ... & PVPlayer expands this, thus reducing the picture quality ...
I have seen threads about RealOne media being able to display fullscreen by editing the realone.cfg file ... But as yet haven't been able to find this file ...
If anyone knows how please enlighten us ...
BSK 😃
thanks guys.
i have one more question. is there a software application that will let me take the films and music videos i have on my computer and downsize them to fit on my 3650? if so what and where is it? thanks for all your time
For .mp4/3gp files you can try PVAuthor from www.pv.com or Helix Producer Plus from http://www.real.com/ for .rm files.
