Hi Guys,i use my communicator 9210 with alot of programes ,but sometimes some programes such as games Doom ,and others ,when i get to start it ,i got a note message ,with not enough free memory ,i'm using 128MB memory card ,so what do you think ......?
what shall i do ...... ???
How could i free up my communicator's memory ......?
Note! Not Enough Memory....
the memory problems have nothing to do with your memory card.
Your memory card wil be refered to as "disk space".
The message means your "Ram memory" (not expandable) is full.
What you have to do is download a program like appman or Switcher to close running applications.
This way you'll free up memory and the games/apps will start.
Note: you'll free up the most memory by rebooting, you can do this by removing the battery, using appman to reboot or using one of the free reboot applications for 9210.
Btw the full version of Doom can free up the memory itself.
I prefer a fast CHR+CTRL+SHIFT +K combination to close almos all apps to free up memory for playng.
If you use this combination you will have your device restarted without having to remove battery 😉
Is like Ctrl+Alt+Del on PC`s :fadein:
