Can't Install to MMC
2 replies · 1,795 views · Started 31 August 2003
For some reason Nokia PC Suite no longer allows me to install apps to my MMC. It's a new MMC, i got it just before i went on holiday and i cant remember if i ever installed any apps to it before. But it hasnt worked since i got it otherwise. I remember it used to give me the option of installing it to 'Phone Memory' or 'MMC' when clicking on 'Install Device Software.' however now it just says 'installing' and when the metre reaches the end it says 'Not enough space on disk' This is obviously referring to my Phone Memory as there is loads of space on my MMC. Anybody help?
Arni
try either confirming that your phone recognises that the mmc card is there, if it does then use your phone to format the card, if it's a 128Meg card it should state; name, capacity, used and free.
