Why is it that only the left earpiece works when I use earphones on my p800? I'm trying to use it as an MP3 player... but it kinda sucks since only one earpiece emits sound. Is this normal?
Only left earpiece works???
No, it's not normal. Get them replaced.
[quote="markiee"]Why is it that only the left earpiece works when I use earphones on my p800?[/quote]
Just a check... but have you pushed it all the way into the slot?
yeah I pushed it all the way... d problem is... I tried 2 different earphones with the same results.
Get your P800 replaced then 😃
No really, looks like there is a problem in your phone, try another earphones, if it still not working, send it to a service center.
Are you using the earphones that came with your P800?
Others have different wiring, so you only hear on one side!!!
thanks guys,
I think it might be an adaptor problem... it works fine when I use the earphone that comes with it... oh well. Thanks again peeps
if your using an adapter, look on it's connecter, see if their is a black ring, if it does, it means it's a stereo adapter, if it's not got a black ring around it, it means it's only mono
