my 9210 was working ok and then suddenley the scroll button on the keyboard fail to work at all and the number of the phones partiallty worked sometimes after pressing it 4 times.if i re boot it will take hours to switch the phone on eventhough the colour screen is on.battery is ok.
any suggestions bar binning the bloody thing.
not responding 9210???????/
How suddenly is "suddenly"? Has it been dropped or something? You could always take it to a Nokia repair center for a check-up.
no trauma to it?
What RAE version do you have on it?
have problem also. can solve it by taking out battery and press all the buttons quite often. one or some of the buttons are stuck and there for the keyboards front and/intern are partially locked
[quote="Anonymous"]my 9210 was working ok and then suddenley the scroll button on the keyboard fail to work at all and the number of the phones partiallty worked sometimes after pressing it 4 times.if i re boot it will take hours to switch the phone on eventhough the colour screen is on.battery is ok.
any suggestions bar binning the bloody thing.[/quote]
