I am trying to connect the Internet using my phone. However, when I install the modem files that I got from Nokia website, it doesn't allow me to choose the Bluetooth one. Only the Infrared one that I can tick on.
I can use my bluetooth with PC Suite just fine.
Can someone help me out on this one?
thanks
erm..do u mean using ur computer's internet connection to surf on ur Fone?
If so,get ur BT serial link with ur fone to the computer on the Mrouter..then use a external web browsing software and u're all set!
no, I want to surf on my computer using 3650 as the modem.
anybody knows how to do it?
thanks
That modem installation program is for nokia BT only, and IR.
Just use the connect option that comes with the BT software that you are using.
yes, the problem is I can't install the modem installation file that I got from Nokia website. It only allowed me to choose IR. The BT one is greyed.
Dunno if it helps, but have a look at this.. http://freespace.virgin.net/bonk.eye might be summat there that might help
