Sending file via BT using P800 Assistant
7 replies · 2,939 views · Started 01 September 2003
Sometimes if I try and r-click | Sendto | P800, it fails.
But whenever I r-click on BT icon in Systray and choose: Applications | SE P800 Assistant | Send a file or application to the phone over BT, it always successfully sends the file. How come?
And... is there, therefore a way, that I can make a shortcut to this Applications | SE P800 Assistant | Send a file... option on my desktop or in the SendTo folder?
Same as mine, i'vehad the same problem but i'm going to try the latest software (.19 instead of .02 or whatever it is) when i can. Have you tried that?
[quote="dawibbla"]Same as mine, i'vehad the same problem but i'm going to try the latest software (.19 instead of .02 or whatever it is) when i can. Have you tried that?[/quote]
Er no.... Do you have a URL where I can get it? :-?
Thanks for the link. That is what I am using at the moment anyway. Thought there was another update....
Still wondering how to get the SendTo working properly though 😉
Ah, worth a try.
Strange thing is i've just tried the same sort of thing with my brother's new 7650 and everything works fine, it's just using it with my p800 and ipaq that it can have trouble :-?
