Vibration 1.0
8 replies · 2,381 views · Started 01 September 2003
I installed an extra language pack to see what it would look like on the phone. I then deleted the extra language (from the Language settings options) and then uninstalled it from Applications.
I now see a listing in the Apps list called:
Version: 1.0
Supplier:Sony Ericsson Mobile Communications
I have no idea what this is. Anyone else seen it or know how to use it?
In my case, 'vibration' was installed together with IM+. I think IM+ use this app to generate vibration alert for incoming msg.
SF
[quote="SonyForever"]In my case, 'vibration' was installed together with IM+. I think IM+ use this app to generate vibration alert for incoming msg.
SF[/quote]
i was thinking about that :angel:
[quote="bigdaddychris"]i had to manually uninstall that file. it was not removed after uninstalling IM+ 😮[/quote]
Well, "Vibration" also comes with AgileMessenger, so perhaps you had that installed, and is that the reason why it hasn't been uninstalled
