Hey, Im a bit of a newbie to this whole Symbian thing and I just really want some help in connecting my 7650 to my PC in order to send photos/files/documents to and fro. Any suggestions/extensive guides??? Thanks a lot!
Pete
Pete
welcome! the easiest way is IR (your PC may already have an IR port), then there is bluetooth, if you have an adapter for the pc. Bluetooth is faster & more convenient, since you don't need to be close to and in line with the IR port of the PC, but it seems more complex to configure (I use IR)
In order, I'd say:
Install PC suite, and read the manual about connecting the phone to the PC.
Should you have any problems, search the threads on this forum, there are a LOT of threads on connecting via IR, and loads about connecting via bluetooth.
Best of luck Paul
