go_boy_zip_plugin7650_10.sis
4 replies · 1,730 views · Started 03 September 2003
Hi All,
Apologies if this has been asked, but i did not find anything on the serach site.
I have 3650 & this file does not load to my phone memory nor mmc.
Do I need this file if i do not have zipman or is there a compatibl file for 3650.
Regards
M
Hmmm. where did you download it?
It is nowhere on wildpalms site..
As far as I know it does not really need that plugin.. And also.. goboy needs zipman to be able to use zip files as far as I have been able to read 😊
Also. From the filename it says it is for the 7650 = no MMC support..
Thanks for the response.
I actaully got the file from wildpalm web site.
When I unzip the files, there were two SIS files.
The first was GoBoy7650_12.sis which installed no problem.
The plug-in did not.
From the readme file: -
GoBoy ZipMan Plugin
If ZipMan v1.2 or above is installed on your phone, the GoBoy ZipMan plugin should be installed.
This will permit GameBoy roms to be sent or added to zip files, and allows zipped rom files to be opened
directly without the need to extract the file.
The GoBoy ZipMan Plugin can be installed by installing the GoBoy_Zip_Plugin7650_10.sis file to the phone.
Have I installed the wrong version of GoBoy?
I have had a look at the site & there is only one version.
Thanks again
Regards
M
You have the right version of GoBoy installed.Like the readme says,the plugin allows interaction between ZipMan and GoBoy which means running zipped (.zip) GameBoy roms on the fly.It is a great idea for devices that are low on storage like the 7650.
Thanks for the response Ghost Dog.
As I have a 16MB MMC I do not need to use this utility when loading games.
Best Regards
M
