hi all, i'm going away for 8 months and want a decent amount of memory, obviously nokia do up2 64mb, which is nice but loads of others do bigger.
now people argue wether the bigger ones work on our beloved 3650 or not can some one pls set me straight on this.
i have seen a fujifilm 256mb SD memory card for �90.
now will this work? coz it sounds great and undercuts other by up 2 �50.
everyone tells me differently. its simple will this work in my fone without crashing or do i have to put up with the over priced offical nokia 64mb ones? there is some serious ergency to this so pls help me and help me now!
pls people who use large memory cards re assure me!
thanking all replies in advance
Big_Head85
SD cards = Secure Digital cards.
MMC = MultiMedia Card.
An SD device can usually also handle MMC cards (SD is a bit thicker & has additional connecting leads), but a device with an MMC reader cannot use SD (an SD card won't fit an MMC-only slot, usually, and the MMC slot doesn't have the required connectors to access all SD features & of course neither does the device software, thus).
Nokia devices use MMC, not SD.
There are 128MB MMC cards and also 256MB MMC cards and some are sampling 512MB MMC cards, too.
Anything larger than 128MB seems risky.
And some MMC cards are more compatible than others also in smaller sizes.
So, best if you can try before you buy (or purchase it with an option to return the card if it doesn't work).
ok so im after a mmc card instead of sd. thats kool.
128 sounds gd, problem: no where will let me test first!! (its so unfair)
and once packaging is open i cant return. so can ppl reply with manufacture names of cards that do work in their fones well.
i now know im after 128 mb MMC but which make????????
HELP ME NOW!!!!!
(pls)
Thanks again
Big_Head85
[quote="big_head85"]ok so im after a mmc card instead of sd. thats kool.
HELP ME NOW!!!!!
(pls)
Thanks again
Big_Head85[/quote]
Here is the one I bought..
http://www.expansys.com/product.asp?code=MMC-128MB
Fast delivery,good product!
It has worked beautifully with my phone all this time..Two thumbs up!
Good luck!
thats exactly wat i wanted and needed. perfect and a gd price also thank u very much.
Yeah a 128MB MMC card should do, there was a list on here that lists the compatible cards that people have tried, i would guess the Expansys cards are on there seeing as though they are so popular and competitivly priced 😊
and long live smee 😉
[quote="big_head85"]thats exactly wat i wanted and needed. perfect and a gd price also thank u very much.[/quote]
Glad I could help.. 😉
