New full screen picture caller ID from SIMEDA
3 replies · 10,484 views · Started 05 September 2003
SIMEDA have just released a PhotoID application. It is a full-screen picture caller ID app for Nokia Series 60 phones.They were beaten by SymbianWare by about 7 days, but you might want to take a look here
Interesting features:
- internal list of images for the contacts, stored separately from the Images application - allows you keep track of the contacts that have images attached to them and change them in one place
- can also fetch images from the Contacts application (not thumbnails though, we decided that looked _ugly_)
- you can take a picture of the contact right from the application, you don't have to start Camera, take a picture then go into the application and assign the photo. Just select the contact and choose "Take picture from camera". You can also load pictures from existing files on your phone
- autostart on reboot
- auto-add incoming calls to the contact list
Here are some screenshots to whet your appetite 😊
The application costs EUR 4.95 and a 15-day trial is available for download here.
Hello everyone,
Version 1.4.1 of our PhotoID is now out (http://www.simeda.com/downloads/PhotoID-1.4.1.zip).
New features:
- United States layout for incoming numbers ( (xxx) xxx-xxxx ) - selectable from the Setup menu
- proportional scaling of images (images smaller than the screen are centered, larger images are proportionally scaled until their largest dimension fits the screen)
- reduced RAM usage (we found and fixed a bug)
- "quick delete" option for the contacts by pressing the "c" (cancel) key
Enjoy 😊
Razvan
Hello everyone,
A new version PhotoID has just been released (version 2.0.0 - download location http://www.simeda.com/downloads/PhotoID-2.0.0.zip).
New features:
1. added "Company" to the list of fields that are searched on an incoming call
2. added support for pictures for caller groups (you can now add a picture for a group of people!)
A lot of bugs were also fixed so if you experienced any problems with previous versions I suggest you upgrade to this one.
Enjoy 😊
Razvan
Hello everyone,
We have just released version 2.4 of PhotoID. Except for a lot of bugfixes, the most important new feature is the ability to change the default image for the incoming calls (so that you don't have to see our ugly-looking one anymore 😊 ).
You can upgrade by downloading the new version from http://www.simeda.com/downloads/PhotoID-2.4.zip .
BTW, if you're in Munich between October 20th and October 24th, you might come and see us in person at Systems 2003 (Hall A3, Stand 407).
Take care,
Razvan
