Updated: Full screen caller 2.0
2 replies · 4,234 views · Started 05 September 2003
It really pays off when you listen to your customers! SymbianWare have released a new version of the Full screen caller application and its a great improvement from the previous version.You can find more information and try it here
[quote="GhostDog"]It really pays off when you listen to your customers![/quote]
That's a good update! The whole program is much more friendly and intuitive now. There are 2 issues that bugs me:
1. When I add an image to a contact, after some time, when I go back to my contact list and press joystick-right, there's no image shown there. 😞 If the caller calls, the image is still displayed correctly.
2. If I choose not to display the label etc, the shaded box should resize smaller since the space is not used. That way I can see more of my image on the background.
Lastly, thought not related to FCS... SymbianWare should update the SmartProfiles to ensure that the vibrator options works. Right now if SmartProfiles is enabled, the vibrator will not work even though it was enabled in the standard profile. 😉
For the next version, how about making it possible to stretch a thumbnail up to fullscreen like in the screengrab you have there?
I appreciate the quality won't be as good but I'd much prefer it to the result I get when I set the thumbnail to 'fit screen'
Cheers!
