got the data cable in(thank fcuk for the tool)however when i try to do anything with it it wont work..logomanager seems to connect but wont upload/download anything!!!
tried a ringtone software but no luck with that either!!
any ideas or links to trial downloads so i can see if it works??
cheers stu
Cable?What Cable?There is no cable connection for the 7650,only Bluetooth and IR and if there is and you have the one that was advertised by dodgy personas on ebay then there is no software for it.
mm well it was from a fone shop,adn iv seen it advertised on the net in a few places!!!
mmm :-?
Soz GhostDog, but there IS a Serial cable for the Nk7650. Very easy to get hold of in the UK.
DB
Yes, thats true, there is a cable, but you cant do anything with it, other than unlock the phone.
It wont work with anything, you cant transfer anything with it. So whats the point??
