Testing HTTP client for Nokia 3650; Looking to share code
0 replies · 4,516 views · Started 05 September 2003
I have been working on an HTTP client for Symbian Series 60 that sends an
image up to an http server. The code I have is modeled after the sockets
example that ships with Nokia's Series 60 emulator. Unfortunately, the code
only works half the time in the emulator and I do not have a real phone to
test it on. Even if I did it seems on-target debugging is next to
impossible. I am confident that the socket code is either 99% correct or
100% correct and is failing due to a bug in the emulator.
So what does all this have to do with the reader? Well, I am hoping to find
someone else who needs a C++ HTTP client for the Nokia 3650 and would be
willing to collaborate in testing my code in exchange for a copy of the
code.
Details about the current code base:
1) I have scanned in some hand-drawn UML diagrams for the code. The
diagrams are slightly dated, but should help the reader better grasp the
flow of the code.
2) The client is single threaded and uses lots of active objects to achieve
this.
3) Unfortunately the Symbian code has no unit tests. Although I tried for a
long time I was unable to devise a test framework that would allow me to
test active objects within the emulator.
4) The Symbian code includes a moderately complete parser for parsing HTTP
1.0 responses.
5) In theory the Symbian code can send anything down the socket that
implements a particular custom interface.
6) There is a simple corresponding Java servlet that saves the image
uploaded by the Symbian client.
7) The server side java code is managed by an ant build system and has some
simple junit tests written for it.
8) Both the Symbian and Java code is maintained in CVS.
I hope someone finds this proposal interesting. I look forward to building
a mutually beneficial relationship. Please send me an email if your
interested.
Sincerely,
James Carpenter
3258-20 Via Marin
La Jolla, CA 92037
Phone: (858) 587-6056
Fax: (309) 418-2935
Email: [email protected]
AOL IM: nawkboyrules
