Hi, I seem to be limited to viewing max 93kb RealOne videos. And native videos at 15 sec max. What gives? Is there a way or a program that allows longer vids to play?
Victor
Victor
you can have videos as long as u like. they just need to be encoded correctly. Use the search function if u want to find out how to encode things properly.
Theres a new video recorder for the 3650 which is called eti video recorder, should be available on this forum. It will cost you about ten dollars but its worth it. You are only limited to the space available on your memory card or phone and can record with full sound. I think with a large enough memory card it would be possible to record for up to an hour.
