BlueTooth or IrDa ?
11 replies · 1,950 views · Started 06 September 2003
Which one is better to connect to my pc to transfer files , access internet or synchronise with my pc. I know blueTooth is faster. But does it really have good connectivity.
Bluetooth is faster & it doesn't require line of sight between the devices (between the infrared LEDs) and the range is longer (up to about 10 meters).
Bluetooth can be trickier to set up (depends on the PC, Bluetooth device & quality of its drivers, mainly).
Personally, Bluetooth for me any day over infrared.
I think i will use a usb device with a xp installed device. Is it easy to use? Do i have problem with device drivers? Does pc suit comes with 3650 recognises it. Thanx.
Bluetooth, bluetooth and again bluetooth... Irda is so much slower 😊
And if you make up your mind, I also suggest that you go for the Gigabyte bluetooth dongle if you can get one...
http://tw.giga-byte.com/Communication/Products/Products_Bluetooth.htm
I managed to install it using the set of drivers that comes bundled on the original cd and I NEVER had any problems with the setup or with the connection of the phone... Everything works like a charm 😊
[quote="Anonymous"]I think i will use a usb device with a xp installed device. Is it easy to use? Do i have problem with device drivers? Does pc suit comes with 3650 recognises it. Thanx.[/quote]
The 3650 does not have USB.
I think what our guest friend is saying is that he will use a USB bluetooth dongle... Right?
If thats the case, then there is no problem... With a little bit of luck, PC suite and mRooter (the program that makes the connection between the PC and the phone) will work just fine with ur USB bluetooth dongle... If not, then its back to the drawing board :P
Are the walls permeable to the BlueTooth waves? Will it be able to charge my phone in next room or downstairs while i connect internet in another room? Sorry of my english 😞
