Security Code Issues
4 replies · 3,276 views · Started 07 September 2003
Hello, i need to get the security code for my 9210 , i dont have the Mbus cable, only the normal one that came with the phone, i have IRDA USB cable, can i do it with the IRDA or its only feasable with the M-Bus cable ?
Cheers
There is a possibility that Logomanager can do this for you,
but I don't know if it supports the 9210 through infrared...
If it does, you can then go to the phone explorer, which can read
the security code, unless you have smart secure installed,
because that disables the possibility to acces the phone through
this backdoor...
Once again: this is a longshot, I haven't tried this myself.
Good luck!
P.S. A Nokia service centre can do this for you as well, as long as you
have warranty on it.
P.P.S. If you have never changed it, it probably is either 12345 or 00000.
Think you can over IR, but never tested it, but make sure you have the lastest LM to do it this you can only do if you can get to the turn the IR, if not then it's m/bus cable, also if you have netmoniter and have changed if from sirel mode to F/bus mode then you can use LM on f/bus.
Standard factory setting code is 55555 latest version of Logomanager will work via IrDa although there are issues with 2000/XP
[quote="Ross"]Standard factory setting code is 55555 [/quote]
I bought a 9210 and a 9210i,
and the standard codes were 12345 and 00000,
think they change per country?
