Does anyone know if this phone, 6600 will be dearer or cheaper than 3650?
price
there has been a lot of speculation about the price 6600 will hit the stores. Some say it will be a bit less than �500, others say more than �600. Until somebody came here with secure sources, I guess it will be between �500 and �550. But that's my guess.
It should also change considering the different countries.
The price should be �500 plus tax.So it will depend on the country you are buying it from but it will definitely be more expensive then the 3650.
In Norway 3 different web-shops have priced the 6600 to NOK 5000 which is approx. �490+24%tax. These prices are without subscription.
http://no.kelkoo.com/shopbot/search.jsp?from=shopbot&catPath=no%2Fmobile_phones&catId=125701&brand=Nokia&model=6600&mn=&mx=&x=0&y=0
"P� lager:
Ubekreftet 01.10.2003 "
Does this mean that it will be on sale on the first of October?
Translation:
"In stock:
Unconfirmed 01.10.2003"
Hard to say if thay are guessing or if thay have som information from Nokia. But since they have stated the price, it may be here soon 😮
Here in Finland Nokia 6600's "suggested price" (dont know an english word for it..) is 660e. Webstores will propably sell it for about 550e-600e, as they always sell phones cheaper than what the official price is.
thanks guys. �500 is probably out of my budget, the 3650 is about �250 here in Ireland .
Having said that the price can drop after a few months as it did with the nokia 7650
(it went from �400 down to �159 and then back up to �400 again!!!)
