Command prompt and copying
0 replies · 1,236 views · Started 09 September 2003
Hello!
Everybody knows you can copy files from and to 9210i using Windows Explorer if you have PC Suite installed on your computer. But how can you copy files from and to 9210i using Command prompt in Windows XP? Is it even possible. I was thinking about a backup script that would copy only some files (e.g. Documents folder) but not all files to PC's hard disk.
Sincerely,
Ari
