please i would like to know your oppinion about which one is the best profile manager. Extended Profiles Pro or Smart Profiles.
I�ve both installed on my device, but i have some "problems" with the two of them.
In smartprofile, when i put the autolock keypad to 30secs, it blocks the keypad after 30scs even when i�m doing something in the phone in that moment.
In Extended Profiles Pro, the program keeps running in background but opened at same time.
Please advise me
Many thanks to u all
Nuno
i dno't get your problem with e profiles but i use it all the time and never had trouble with it so my advice is e profiles
Hi
my problem with eprofile is: the program to work, it must keep opened. When i press the key(meny key) to show the open applications, it show�s me the eprofiles, or there is another way to put the program working but not visible (like smartprofiles)?
Thanks for your oppinion
Nuno
e profiles is always working but ist worked away so your phone will not show it but is working
When you use custom alarm and clock ringtone in SmartProfiles, your vibrator will stop functioning. 😞
If I've not mistaken, with ExtendedProfilesPro, the original alarm/clock sound will still sound for a split second before your choice of sound will start.
also have no probs using EProfiles... happy with it.. love the schedules cuz i always forget to switch.. a must have.. 😃
I am using Profile Scheduler by www dot DrJukka dot com
