does sucha headset which you can also talk into exist for the p800??
Decent headset with volume and track control
yeah, you can get a little kit which enables you to use your own set of earphones which will be converted through the kit down to 2.5mm to fit into the p800 socket. i think it costs $18,
alternatively, you can get a 3.5mm socket plug, splice the cable, then get a 2.5mm plug, splice it and either link the wiring together, or cut the two cables off, and get a new wire and thread it from one plug to the other, this will result in the same kind of thing if you can't pay in dollars like me and i think worked out, it's cheaper (i only came up with this idea because my local maplins store only sold a block converter, which will mean the whole plug is sticking out of the p800 which isn't good when i have it in my pocket)
talking into it won't be poss though, oooo, which reminds me to create my splendid thread :angel:
cheers dude but i kinda need the whole shebang , talk and control.
Its kinda annoying because my Samsung MP3 phone which i got 2.5 years ago could do this!! u would a thought that Sony would implement this basic requirement on this fone
OH WELL! :cry:
found an adaptor that does the job!!
[quote="spacedude"]found an adaptor that does the job!![/quote]
Mind sharing what adapter/how much.
