n3650 problems..
2 replies · 1,639 views · Started 11 September 2003
I just have some questions.
i have got the n3650 connected to my ciomputer by bluetooth.
its working fine.
but how do i get nokia pc suite working?
i tryed the ports that you can select in the pc suite,byt they are all com ports,ir ports and cabel ports that you can select.
nothing works....ive tryed them all...they display nothing.
is bluetooth really a com port?,i have a msi btoes usb bluetooth device.
please help me whit this.
and i haveone more question,i have installed a mp3 player on my 3650..and when i send mp3 song trhou my blutooth device ,everyting comes by mail to my inbox.so i just wonder if i can save the mp3 song on my mmc card insted of the phone memory.
hope someone could help me...i would be so glad...
evol wrote:everyting comes by mail to my inbox.so i just wonder if i can save the mp3 song on my mmc card insted of the phone memory.
There are basically two things you can do
1) Use the MMC for your inbox so that all incoming msgs, Mp3s etc are stored on your MMC automatically.
or
2) Install a file manager on your phone, and use that to locate the MP3 files in your mail box (on the file system) and copy them to your MMC
1) is easiest: From the phone menu goto 'Messaging' -> 'Options' -> 'Settings' -> 'Other' and change 'Memory in use' from 'Phone memory' to 'Memory Card'.
2) I recommend FExplorer. Use the Find functionality to locate *.MP3 files in "c:\system\mail" and copy them to somewhere on your MMC (e: drive). I don't know if your MP3 software willl be able to find them this way though.
Here is how I connected to my PC via BT Dongle from my N3650 for the first time.
When you load the BT software, there will be a BT icon on the bottom right side of the menu bar on your PC.
Right Mouse Click & start the BT.
By double-clicking the BT the Windows App is launched.
Select find BT Devices, select the Phone device.
You will require to enter numberic password on PC & re-enter the same password to the phone.
Both devices should now be paired.
Go to configure BT & select the COM PORT that the BT is attached to & save configuration.
The BT Icon turns green on PC.
Launch PC Suite & it will ask you the Phone Name that you would like to assign, click OK.
Hope that helps?
M
