Connections over GPRS - HELP Needed
7 replies · 2,125 views · Started 11 September 2003
hi i trying to establish a connection between P800 and a server connection using GPRS to send and receive files.
Any suggestions how to get started... 😃
Thanks a Million....
[quote="ahkel"]hi i trying to establish a connection between P800 and a server connection using GPRS to access its TCP/IP.
[quote]
your trying to conect your p800 to a server over gprs...to access it's tcp/ip.... i don't think that makes sense, tcp is a service which reduces the loss of packets of data from node to node which the ip loses. however, both of these and sockets make up the internet, the process being a way to collect the data from the appropriate source. (oh yeah, this is just my knowledge, it could be totally wrong) :angel:
You'll be using TCP/IP to access your server anyway.
Can you be a little clearer?
the problem is the your talking about 3rd Generation Networks ... that Only Depends on LARG Pakets of DATA transmited as TCP/IP
to Support Video Conferancing over mobile phones which needs a huge and Fast Data Transmision .....
our Dear p800 is a 2.5 Generation phone
u cant make IP telephonywith GSM .... it's Really more expensive than calling with regular GSM network !
Peace To our Naighbors in Phalistine ....
God Get rid of Bully America
hi sorry if i didnt make my question clear
okie what i am trying to do is after taking a picture from the cam, den establise a connection and sent it to a server. At the same i can get the picture taken back into the phone....
pardon me for my poor usage of language..... 😃
[quote="ahkel"]hi sorry if i didnt make my question clear
pardon me for my poor usage of language..... 😃[/quote]
[quote="ahkel"][quote="ahkel"]hi sorry if i didnt make my question clear
pardon me for my poor usage of language..... 😃[/quote][/quote]
if you send it via mms, then it'll be sent somewhere while retaining a copy of the picture on your phone, or you could use a programme called FTP800, it allows you to use your phone as a FTP client
