Any way to uninstall the original 3650 apps?
2 replies · 2,408 views · Started 12 September 2003
No, as they are in ROM (Read-Only Memory). On the other hand, while there, they don't consume any resources (RAM/C-drive/CPU), if you're not using them.
[quote="Arni"]Is there any way of uninstalling the original 3650 apps such as RealOne, Video Rec?[/quote]
If you don like tat program go open a new folder and trash it in until u need it then use la
