I'm not requesting this so dont go mad at me about 'warez' i jus wanna know if it exists for the 3650? Then i'll be on my way around the net...
Thanks 😉
p.s. NOT the 7650....its not compatible with the 3650.
Thanks 😉
This Dopewars version, works on my 3650. 😉
I have the same version on my 7650 and my 3650, even though the installation said 'may not be compatible' it works a treat 😊
I've got loads of different version but they all say 'Not Compatible with this phone. <Abandon> ' (abandon is the only option available. 😞
[quote="Arni"]I've got loads of different versions[/quote]
Loads of different versions??
If you are thinking about the dopewars game made by Palmanac Dopewars, then there is only one version??
Ah yes. There is a J2ME Dopewars edition by RedTeam, But I doubt that is the version you are thinking of.
So it puzzles me a bit you are saying you have a lot of different versions?
what i meant to say was i downloaded it from various locations, some have different filenames. soz.
Bottom line though, it doesnt work. For NO reason!! :evil:
Try this method.
Send it to the phone using bluetooth ( not installing using pcsuite installer).
Then open the message containing the sis file and install from there.. When it says. File not compatible with phone, answer no to abort installation. Should do the trick. Works for me ( at least with the trial version. Don't think it is different with the version you buy)
But. erhmm.. Downloaded it from different locations? there are not so many (legal) locations it can be downloaded from. Try and use the legal ones. With that you can be pretty sure it works 😊
k , i got it installed. I moved the .sis file to my phone and installed it from there, rather than installing from my PC. 8)
Can I download Dopewars full version without paying for it somewhere?
thats an illegal question my friend!
[quote="joris19"]Can I download Dopewars full version without paying for it somewhere?[/quote]
Probably. But that is illegal and not something that this forum takes part in. Request for warez is not done here 😉
If you on the other hand are looking for the demo version. here it is 😊
