*#7370*
2 replies · 2,010 views · Started 12 September 2003
This does not work for me as my lock code is not responding to the default number.
The Lock code has never been amended.
I have taken the phone to CarPhoneWareHouse where they have spent three days trying to flash my phone.
They get error inconpatible code 0511504.
Problem is they have to send my phone to Nokia (taking weeks & weeks).
Is there another way to reset my phone or does anybody know a work-arounbd to this?
Your assistance is appreciated & if unresolved my phone will be in NOKIA's Hands-not the best option...I hope.
Please Help.
M
try system tools prom psiloc it will format your phone ass well is use this when it format my phone cause the code does not work for me either
well, if you are using the code that you wrote for topic, then no wonder it doesn't work!
The correct code is *#7370#
and NOT *#7370*..
See the difference? 😃
Cheers
