Phone preferences | GSM Networks | Add... South Africa list?
1 replies · 2,418 views · Started 12 September 2003
I can't find the list of South African networks. Is this list sorted by country?
If so, is South Africa then listed as starting with S... or its country code starting with Z... (ZAR)?
I would like to add the networks to my favourite list but have missed it somehow. Anyone know where they are listed...?
Networks are:
[list]MTN
Vodacom
Cell C[/list:u]
I never worked out the sort order, but they are probably in there somewhere, you just have to scroll down through the hundred or so entries.
You will probably need to do this twice. At least, when I was adding first Latvian then Russian networks, in each case the first time I did it, it reset on leaving the country, but the second time it seemed to learn, and now works fine.
