What Program?
3 replies · 1,273 views · Started 14 September 2003
I found this pics and it's great. i'm wondering what program should i use to change icons, can somebody tell me. thanks 😊
It's a very complicated procedure where you have to use the Aifbuilder from the SDK and design your own icons in Photoshop etc. You also need to have a language pack installed in your P800...
So basically it's alot of hard work, and not very easy if you don't have any programming and design skills...
If you don't feel like doing it yourself, you can wait and see if someone releases some icons they've made, and then all you need is to have a language pack.
