I have a feeling I must be missing a trick somewhere along the line here, but I've read and re-read the 7650 user guide. I've read all the forums here, and picked up as few tips. But still can't connect
Problem is:- I've had the service settings sent as a smart message from www.02.co.uk. I open the message; select <save all> and the phone confirms to me that it's saved.
Tools -> settings -> connection -> access points
now lists o2 as a viable access point. but when I go to
Services -> options -> settings -> it's not there to be selected as a default Access point.
why isn't the entry in connection settings available to the seettings in services?
can anyone point out where I've gone wrong.
Is it cos the smart message I received was intended for a 7110?
Surely it's the same basic information details isn't it?
For a access point to be listed on the 7650, you need to define a gateway and a homepage. That was not needed on the 7110, I think.
I'm pretty sure the settings message I received inclused the gateway and the homepage.
I've got the homepage added to my Services bookmarks, but no valid access point has been defined apparently
[quote="fylshearer"]I'm pretty sure the settings message I received inclused the gateway and the homepage.
I've got the homepage added to my Services bookmarks, but no valid access point has been defined apparently[/quote]
Are you sure? You definately need to add the homepage and WAP gateway IP address to the access point, otherwise the WAP browser will do just what you explained - it won't show your access point because it is not a valid WAP access point (i.e missing homepage and/or WAP GW IP).
And for 7110 you need the IP address and starting page URL too, every WAP browser needs those things before you can use WAP.
[quote="Zark"]
And for 7110 you need the IP address and starting page URL too, every WAP browser needs those things before you can use WAP.[/quote]
ok, you're a star. I thought it would put two and two together itself.
system works now.
