[New] MyHandware releases FileMe for P800
0 replies · 2,374 views · Started 14 September 2003
FileMe is a virtual filing system that sits on top of that provided by your phone. By bringing desktop-like file explorer functionality to your P800, this one application turns your P800 into the powerful handheld computing device you always wanted it to be.
With FileMe installed, you are no longer limited to storing
your files in application specific folders. Store images,
with text, with sound, with any file you want! Place folders
within folders creating the tree like structure you are used
to. With one handed scrolling via the jog dial and a rich
suite of file manipulation commands, you are truly in
charge of your data.
Plug-in Editors
FileMe uses proprietary apps for viewing and editing files.
Just like on your desktop, one click launches the app
associated with that file. No longer do you have to open
the Picture viewing program before you can navigate to the
image you want, with FileMe's file centric view of your data,
one tap, or press with the jog dial and you're there!
FileMe comes free with NoteMe. NoteMe is a text editor
plug-in to FileMe. Edit text files on the move then sync
with your PC at your leisure. Worried about security? NoteMe
incorporates powerful password encoding software to
stop prying eyes looking at your sensitive data. No need to
buy expensive encryption software then spend days typing
the data into a format that can be shared with no other
application on earth. Encrypt any file you want, on your
phone, on the move, with NoteMe.
Why not download PictureMe - a free image viewing plug-in?
Other plug-ins coming soon for FileMe:
DrawMe - image editing software for your P800.
WriteMe - create rich text documents on the move.
TableMe - want to create and view spreadsheets?
StoreMe - the only mobile database you will ever need.
