Hi to everybody...I need a little help!
On my N.3650 the time in the registry call is behind of 1 hours!! :-? I don't know why this.... the hours is regularly set on my local time but the registry no! What's the problem ? Did this problem happened to nobody ?
PLEASE help me!
TNX!
u mean call logs rite??
even i have the same problem my logs are 30 minutes behind i did search for it in the forum found a thread but was inconclusive so any guys could help firmawre is 3.16.
Remove the auto time update function, found in clock settings. I am pretty sure your logs will not be behind anymore 😊
hey but thn the time will not be updated rite ? like everytime i start the phone i will have to set the time
[quote="yogs acxtually"]hey but thn the time will not be updated rite ? like everytime i start the phone i will have to set the time[/quote]The time will not be updated from the network (if the network supports it). You'll only have to set the time, if you remove the batter for a longish period (I don't know how long it is, but long enough to swap MMCs or SIMs).
Hi guy.... tnx to help me!
So, my auto time update is disable ...
I'm trying with my battery...
this problem is appeared from little time, before worked well!
Help...this is a annoying problem!!!!!
TNX!
hey i disabled the auto time update function but the problem persists still
my logs are still 30 mins behind
Try phone software reset.
1. If you have programs installed in MMC card, remove them first before proceed second step. Those installed on phone memory need not remove as phone software reset will remove them.
2. On Standby screen, key in *#7370#, and you'll be prompted
" Restore all original phone settings? Phone will restart.",
press "Yes" to continue and then key in "Lock code" (by default it should be 12345 unless you have changed it) and phone will begin to reset all the phone software and restart by itself when finished.
3. Once phone restarted, it will prompt to key in new time and date, do so as it prompted.
Try above steps to see if it help to solve your problem.
No improvement then probably you'll need to send the phone to Nokia SC for repair.
