I've been trying to encode mp4 files to play on my A920 (using MPEGable)and I'm having no luck whatsoever. Every time the phone says it is unable to play the file.
Any help and advice on maybe different programs to use or what I'm doing wrong (ie. common mistakes) would be really appreciated.
Thanks,
A920Fan
use quicktime - the full version to encode '3gpp'files - the a920 will play these. well mine does.
safe
Quicktime is a tool of the mac and will leadeth you to the dark side 😮
To use mpegable properly you need to change the graphics and sound to settings work best with your phone.
try these settings for your a920
codec:h.231, 176x144, 150kbits a sec (200 seems nice to me as well)
audio: acc 96kbits (above this the audio does not sync when entering full screen mode on the phone.)
Also try lowering the frame rate to 12.5 or 12 (the a920 can support upto 15 but has difficulty with sync at fullscreen.)
Hope this helps 😃
first off, hi =) i recently got my A920 and am very happy with it. hopefully i can find some nice info and software here on the forums.
the MP4 thing; i wondered what they were too. i took the TeamMotorolaPrepares.mp4 video off the CD and had a look at it. here's what MPlayer has to say: it's definitely a quicktime file format, with some sort of "Major-Brand" tag of "3gp4. MOV track 0 was the audio stream, 16 bit 2 channel, and a fourcc tag of "mp4a" ... MOV track 1 was the video stream, image size 176x144 at 24bpp, display size 320x240, fourcc "mp4v", 20 fps.
if it's playing MPEG-4 video (and the documentation suggests it can), you might be able to just get away with shoving the mpeg4 video into a mov or qt file. it might even be able to play them from an .avi file format.
i'll do some testing and report back, but it'll have to wait until i buy a nice big memory card 😊 i want to re-encode some of my movie files to play them on my phone, too 😃
-Neko
this works for me.
us Pv Author!. get trialversion at = http://www.pv.com/shop/authordownload.asp.
ENCODING 128,000bps .
CODEC fan. Audio gsm-amr off. ACC on= 32.00 kbs
Video:
CODEC= PV MP4
VIDEO SIZE=176X144
CODEC SETTING
Frame Rate=from 2.50 too 25.0. works 4 me = 12,5
I use this one and it works perfect.
http://www.forum.nokia.com/main/0,,034-63,00.html
You have do register first.
And remember to press: Request serial number for this product. It's right under the DL button.
Sismo - Enjoy!
