File Manager in 6600
7 replies · 4,279 views · Started 15 September 2003
Just looked through the 6600 manual that was posted together with the FCC approval. It looks like there is a file manager included.
Great I think - Even though that 3rd party versions is quite cheap!
Eagerly waiting to get a hold of the n6600...
do you have the second part of the manual? I just get an error everytime I try to open it. I downloaded the first part with no problems, but the second one... do you have it?
For secend part you need to install Acrobat v6.0 they can recovery damadge file, read a my post at this link:
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=16703
Thank you for the tip. It worked.
The file manager seems to be the same as N3650. It doesn't replace my Handy File.... 😊
[quote="Al3xandr3"]The file manager seems to be the same as N3650.[/quote]
N3650 does not have a File Manager.
File Manager in N6600 does not show ROM, nor does it show any system folders. You can view only images, sounds and videos in phone memory (c: drive) and all non-hidden folders on MMC.
I don't have 3650, but I have a friend who does, and I could almost swear that it does have some kind of manager... but, I might be wrong... :-?
I have had a n3650 and I have never seen a file manager build-in! So you might be wrong.
It does not sound too good that the file manager only browses images, sounds etc. and not system files etc.
Then I will have to install 3rd party!
