A920 and bluetooth
4 replies · 2,523 views · Started 16 September 2003
Phoned the 3 technical team and they stated that the phone will be bluetooth enabled when the software is updated and when the phone will be allowed to function as a modem !!!!!! So sounds kool to me.
For what it's worth - I had a P800 prior to the A920 and I believe this phone just kicks the p800's butt as it doesnt look plasticky!!!!!!
[quote="gurdip"]Phoned the 3 technical team and they stated that the phone will be bluetooth enabled when the software is updated and when the phone will be allowed to function as a modem !!!!!! So sounds kool to me.[/quote]
SO you are saying that the bluetooth only allows you to use A920 as a modem.It can't pair with other devices such as other handphones or bluetooth headsets? This is bad...sounds like it's the same as the nec e606 where it says bluetooth enable in the manual.After a few months of use with it and found out that the bluetooth is for the nec e606 to act as a modem only. This is really bad. Is this information misleading or what?
[quote="gurdip"]For what it's worth - I had a P800 prior to the A920 and I believe this phone just kicks the p800's butt as it doesnt look plasticky!!!!!![/quote]
Definitely agree with you here !!! 😃
NO NO NO NO . I was informed :
1. Bluetooth will be enabled - so u can use it like any other bluetooth device.
2. The phone can also be used as a modem !!!!
It sounds ace that you will be able to use it as a modem. However, I'm sure it will support headset proocols and the like as one of the prizes in the A920 developer competition is a bluetooth headset isn't it?
Yeah, we've got it from a few different sources within 3 that it's gonna support Bluetooth profiling ...
J
