firmware
11 replies · 1,923 views · Started 16 September 2003
:robot: what is the latest firmware version for 7650? :robot: [/code]
what's the latest on the firmware? other feature added? does the nokia video cam is now included?
Information taken from this thread http://allaboutsymbian.com/phpBB2/viewtopic.php?t=15993
Changes made from version 04.46 to version 05.06:
Call and network management
-Voice mail indicator handling changed, now indicator is displayed correctly.
SMS
-USSD menu handling changed, now correct USSD menu is called.
Other changes
-Alarm Clock: Now alarm is ringing correctly when alarm is set at 8.00
-Advice of charge implementation improved. Now call cost limit is showed correctly on the screen.
-Memory allocation improved.
If I was you, I'd ring up some of the NSCs there, and as well as checking what version they have, see if they will do it while you wait.
You can find a list of NSCs in the support section of www.nokia.com
[quote="mjsee"]confirmed! v5.06 is now available in the semicon, philippines[/quote]
I going to upgrade my firmware to v5.06 later here in Singapore... 😊
Just upgraded my firmware to 5.06, restored everything back from PC Suite, however a little disappointing cos the handsfree mode is still as soft as before. Was expecting a little more... 😞
