😮ops: nokia multimedia convertor can be use to convert mpg to .3pg and mp3 to amr. u can dl the software and convert what u wan and infra to ur hp.
dude can we have the link plz
http://www.nokia.com/phone/3650 and proceed from there.
I'd rather do it manually converting my MPG to AVI doing some resizing and this video crap, mainting good quality and big size (the biggest you can get in real one that is) then use PV Author and convert to .mp4 maintaining the highest quality possible, playable, transferrable (you don't want it huge) then put it in Real One and enjoy 😃 (i think you'll have to skip the "enjoy" part, cause it's STILL too small to be enjoyed, the same piece i had on the 3650 (an episode from Family Guy) I had it on an XDA, or Q-tek to be exact, and normal size, it was perfect!! Full screen an all)
I'm not promoting pocket pc in anyway :roll:
:P
can you give us a new links cause this one is not the link to the software, can you please post it cause i can't find it on there site
thanks
Seems easy enough to find, if you start with the place I said (http://www.nokia.com/phones/3650).
When there (or where ever you are redirected), select "Software" from the left-side navigation menu.
Then on the resulting page, selected the only link provided "Nokia 3650 phone support".
Then see the "More software" part that reads "Nokia Multimedia Player, Nokia Videorecorder Update and More Software".
Of course, the page design could be simpler, more straight-forward so that the "Software" link on the first page would skip all the unnecessary steps and just show the list of all software.
In any case, it isn't that hard to find. 😉
And if you follow the instructions above, you will end up here: http://www.nokia.com/nokia/0,5184,5371,00.html
i found that to but there is no converter only a player for 3gp files 3650user said that there was a converter to make 3gp files??😞
Oopsie. 😊 Try this the Multimedia Converter here:
http://www.nokia.com/nokia/0,8764,1910,00.html
thanks N/A i was looking for that one
