anyone here uses Globe Telecom as their Service Provider?
4 replies · 4,982 views · Started 17 September 2003
i got error "invalid multimedia access point. check multimedia setting" what does it mean? it pops up everytime i restart my phone mi'm using n3650 help pls tnx!!!
Have you MMS messages in your Outbox (but no default - or incorrect - MMS settings defined)?
Have you installed some software that's automatically launched when the phone is reset (& trying to make a connection somewhere for some reason)?
ehehe its ok now, i dunno what happened but its it's fixed! tnx
i'm having a problem like u, error message is "invalid multimedia access point. check multimedia setting" but may load is P1.00 and trying to send a MMS, but didn't try after i reloaded, does globe has a bug on MMS?
and the other day, i have my MMS enable long long ago and just like 2weeks ago, i recieved a MMS but it said that i need to go to the website to check my MMS msg, weird?!
go to globe.com.ph and look for the mms settings there.o kya type GO N3650 tpos send mo sa 2951.mkkrisib ka ng configuration message.bgo mo masave you will be prompted to choose between primary and secondary connection.choose the former.mail me at [email][email protected][/email] kung ano nangyari.sna nk2long ako
