I don't know whether this has been touched in another thread - but I am not able to find it 😮
Will the n6600 support both datawise Bluetooth and audio Bluetooth???
Yes; the data-only Bluetooth limitation was only on the very first Series 60 phone, the Nokia 7650. Everything since has and will support Bluetooth audio (headsets/handsfree), if it has Bluetooth at all.
Sound great to me! I will start looking for a Bluetooth headset right away!
PS! Do you know of a good and reliable place to buy a bluetooth headset online! ??
The new Nokia HS-3W BT headset has just been released. Just ordered one togheter with the 6600.
http://www.expansys.com/product.asp?code=105828
The Nokia HS-3W BT headset looks a bit weird to me. As I see it I still have some kind of cable!
I want a model with out any cables and I am not only interested in Nokia.... Just a cheap model!
Just learned about this one. Plantronic MX153 44.95$
Heard a lot of good things about this one. Plantronic M3000 139.95$
Good friend of mine has this. Pretty ok. Jabra BT200 49.35$ approx
Thanks for the information!
I will look in to it!
[quote="WiLDCHiLD"]The Nokia HS-3W BT headset looks a bit weird to me. As I see it I still have some kind of cable!
I want a model with out any cables and I am not only interested in Nokia.... Just a cheap model![/quote]
Yes, and thats the point. It combines the lightnes of a small airpiece with BT. I still think the other BT headsets gives mee the cybernerd feeling... And the price in Norway is $90.
Pros:
- Small and lightweight
- Easy to attach to ear when you get a call
- Better battery life?
Cons:
- Still has a cord
- Two piece system
Aksel
Does anyone know if these bluetooth headsets can be used to perform additional functionality on the phone. If i wanted to do something other than make a phone call when pressing the button is this possible?
