IS there a way to lock a certain word or sheet file .. which I might save important data in?
Or is there a way to have a secret area in my Communicator? .. some one told me that I can have a secret (Password protected area) in my Memmory card bu I failed to do that .. I think my Memmory card type doesn't support this function.
Is there a way to lock a file in the 9210i
[quote="Abu Adham"]IS there a way to lock a certain word or sheet file .. which I might save important data in?
😉[/quote]
Try to use SecureDrive from SymbianWare.
SD is a unique program that allows you to keep your data in secure form without you having to think about it. All these actions are performed "on the fly" and are transparent to you.
The Program adds new disks visible as regular disks and you can work with them as with regular ones � store your files there, install applications onto these disks, run them, etc. But you can be sure that your data is confidential.
For more details look here: http://www.symbianware.com/product.php?id=sdrive&pl=n9200
Greetings from germany, Hartmut
