mmemorey stiker
3 replies · 2,031 views · Started 20 September 2003
im wondering most i turn of my a920 to remove the memorey stiker?
s/he means do you have to switch the phone off to remove the SD card.
Answer is NO its hot swappable
[quote="Anonymous"]s/he means do you have to switch the phone off to remove the SD card.
Answer is NO its hot swappable[/quote]
ok tanks :angel:
