How can you get this to vibrate and ring when someone calls, i can only get vibrate or ringer not both. :agrue:
Ringer and Vibrate together on a920
Booo ... you cant! :cry:
It's true as well, how the hell did they miss that one? One for the next Firmware I reckon, along with IR and BT.
Still a great phone though, hehe.
This stupid thing that motorola have done, with the vibration and the ringtone not working on the same time, is just in the software apparantly, some guy i spoke to thougt it was an extra thing for them to do to make them not work together, why would the whant to do that. But one guy wrote a program called Vibor (VIBrate On Ring) witch makes this possible, you can get ir here: http://nop.at/vibor/ verry expencive though =(
Hi - its possible and i've done it without the help of VIBOR - though i've gone up to the a1000 now I'm pretty sure the way listed in this post will do the trick.
It is a shame, profiles cant be the hardest thing to implement. luckily the a1000 uses the speakers in the a1000 which have the equiv of a sub woof that produces the vibrations, so you can make your own ringtones with low frequency waveforms in the background so it 'vibrates' at the same time.
Hope it works, let us know...
Mitch
spudtheimpaler wrote:Hi - its possible and i've done it without the help of VIBOR - though i've gone up to the a1000 now I'm pretty sure the way listed in this post will do the trick.It is a shame, profiles cant be the hardest thing to implement. luckily the a1000 uses the speakers in the a1000 which have the equiv of a sub woof that produces the vibrations, so you can make your own ringtones with low frequency waveforms in the background so it 'vibrates' at the same time.
Mitch
a question is how to find the default vibration file on A925, because it is in hidden folder which is not shown on PC.
