is there a way to do this without being able to get to the normal menu? I can't get to the applications menu when the MMC is in the phone. I take it out and the phone works fine, so I'm guessing the MMC needs to be formatted
Formatting the MMC?
You can reformat the MMC by using a memory card reader then reformat it again this time using your N3650. This sort of makes the MMC compatible with the phone again. Try it. It worked for me.
secretninja wrote:is there a way to do this without being able to get to the normal menu? I can't get to the applications menu when the MMC is in the phone. I take it out and the phone works fine, so I'm guessing the MMC needs to be formatted
system error appears on my phone when i insert my memory card but when i remove it my Nokia 3660 works just fine with just the phone memory. what shall i do?
Try reformatting the card (first in the phone, and if it doesn't work in a PC-based memory card reader with FORMAT d: /FS:FAT). If that doesn't help, return the card to where you bought it or the manufacturer and try another brand instead.
OOOOOOOuuuuuuupppppsss the same problem with my MMC.....
I was desperate but......
Thanx!!!!!!
