One step closer to unlocking the A920
1 replies · 2,915 views · Started 23 September 2003
http://217.64.228.218/cgi-bin/yabb/YaBB.cgi?board=news;action=display;num=1063704385;start=0#10
For you guys who arnt registered with the '3' developer forum:
-sof-
If you're talking about actually putting it on a handset. The answer is yes you can but only if the handset has the TOCSP certificate and key installed in the cert manager.
Can you wait until tomorrow though as the SDK has some known errors and ommisssions which are reported elsewhere in the forum. I'm hoping Motorola will have a resolution to these .
If not I will rollback to the previous version. FYI this would 102 Mb soif you're short on disc space you'll need to check the readme.txt as to what the minimum requirements are for each SDK.
-eof-
There is rumors that you will be able to put certificates on the handset when the IR is enabled.
ALSO....
If you go onto your browser (opera) and type this in:
File://c:\
You will have full access to your a920's c:\ if you download the file you can put it on your d: (other media) and view on your pc.
(sorry if this is a re-post)
